I made a Lithophane and thought I would try out the 0.2mm nozzle I got a while ago. I first tried a Textured PEI plate, but the first layer was really bad, with balls of filament and empty spots. I cancelled that print and changed to the Cool Plate SuperTack. Re-sliced using the different plate and even though the first layer looked pretty bad, it didn’t have balls of filament showing up so I let it complete.
When I removed the print, it left some of the first layer behind, but it also scratched the plate, badly. The Textured PEI plate did not get scratched, even though I let it get into the 3rd layer before cancelling. See the picture of the CoolTack plate after I removed as much filament as possible by printing a thin cube using my 0.6mm nozzle.
I am now wondering if I should have re-calibrated after changing nozzles. Any ideas why it did not scratch the Textured plate but did scratch the CoolTack plate?
As an aside, I had created the Lithophane for the 0.2 nozzle, and then printed 2 copies, one with 0.4mm nozzle and one with 0.2mm nozzle. While the print made with the 0.2mm nozzle was slightly sharper, it certainly was not worth the more then 2x print time.
