With the latest update, i decided to try the 0.6 nozzle i ordered. The new algorithm is supposed to control line width much better and produce results on the 0.6 similar to the 0.4 while having a speed advantage.
Based on my testing, i could not achieve any significant speed advantage. It seems on the 0.4 nozzle this printer already pushes the limit of the melt rate and going to a wider nozzle does not improve things.
Here are some prints:
This one was done using 0.6 defaults with my tuned eryone silk pla but layer height changed to 0.2
It had very noticeable artifacts, seemed to under-extrude despite me bumping the flow multiplier a bit.
The top layer was actually very clean
The speed difference at 0.2 layer height was about 10% between 0.6 nozzle and default speed and the 0.4.
So there was significant degradation in quality for almost no gains in speed.
This is the same print on the 0.4 nozzle:
I had the same issue with 1 layer being off arround the middle, not sure what that’s about. Overall the quality is much better.
The top layer inside the boat was actually better on the 0.6 nozzle.
I decided to try to print faster on the 0.6 hoping there would be a decent speed difference and tried to match the speeds on 0.4 but reduced them a bit.
I used babmbu pla since i figured it’s the easiest and best tuned. Turned out really bad and i stopped the print
I made one more test using much lower speeds for outer wall and played with temp and line widths a bit, there was an improvement but not much better than the first test with a very minor speed boost.
Overall – i dont see a reason to go for 0.6 if you print PLA on this printer. I think it is very heavily tuned for a 0.4 nozzle and it pushes the limits of the material.
I did not test this with ABS, but i expect that will flow better and might see some improvement.
I’m sure my settings could be tuned much more and produce a good print, but i feel like it will end up being about as fast as 0.4 once i get there. I did not see any significant strength increase and to be honest, i see no benefit to the larger nozzle.
Worth noting that i was printing with silk and lowered the speed to make it shiny, if i didnt care about that, i could bump the speed up significantly and still get an almost perfect print, probably faster than with the 0.6 nozzle.
I did not optimize placement on the bed, the best result is by slightly angling the print and placing the front slope facing the aux fan. I left this in the middle with the slope facing away from the fan.
Curious what other people’s experience might be.
Bonus:
My marble PLA just finished drying, and other than the print popping off the bed, it looks absolutely stunning
