Hi, can anyone give me a tip as to what the problem could be? I use a BambuLab X1C with a Panda Revo hotend and 0.8 nozzle. I use all the standard settings except that I reduced the retraction length, which has improved the issue a little. The filament is BambuLab PLA. The issue is that there is always a large distance between the wall and the infill. Furthermore, a flow calibration test looks very strange. The flow ratio is set to 1. If someone has any idea what I should look for, I would appreciate it.
Filament flow rate calibration? Do a few tower calibration prints that might help detefmine where your problem is. Try different settings as well while you are at it. That also might help determine what the problem is.
I had similar issues of all kinds after switching my .4mm nozzle to my .2mm nozzle to print some really detailed parts. I had done so in the past with perfect results and was dismayed at how none of my parts would stick to the print bed properly, and if they did looked very lined and poor quality. As a newbie, I thought my printer was failing. After a week of trying different build plates, Aquanet, glue stick etc., I found that the problem was I had forgotten to tighten the two screws holding the nozzle on, after I had plugged in the three nozzle electrical plugs, I forgot to go back and tighten the two screws down all the way. It was not obvious at all, until I decided to reinstall the nozzle all over again. Operator error, but as we said in the Navy, “inspect what you expect”, so maybe take the nozzle off and reinstall or inspect it. Long shot, but I would still be pulling my hair out if I did not check.
