2 ams units no hub h2s
i have the AMS 2 pro that came with my h2s and i have a AMS unit that came with my p1s i want to connect the normally AMS to my h2s to print with 8 colors
is this possible without the pro hub ? ive googled before asking and cant get the solid yeah or nah
In short, yes, but you need one more part.
You only need to plug one of these into one of the inlets and the plug up to four AMS into it of any mix if AMS, AMS 2Pro & AMS HT.
https://wiki.bambulab.com/en/ams/manual/multi-model-AMS-compatibility-guide
If you don’t mind me reviving an old thread for tangental questions…
I have an H2S and two AMS 2Pros. I accidentally bought filament hubs before I learned I only needed 4 in 1 PTFE. Can I use the hub with the H2S. I can’t find anything that says it isn’t supported, and it seems like the software would work with it. I think it’s just not recommended.
My reasoning: it looks/mounts nicer and has an additional buffer.
Here’s what Bambu said in case anyone else is wanting to know.
“Kindly note that you can use the AMS Hub to connect the AMS to the buffer without the 6-pin cable as a replacement for the 4-in-1 adapter.”
