So I just finished setting up a 2 plate print file in the slicer. I sent the file to sd card on the printer. I guess I expected it to upload 2 different files but both plate are in the same file. How do I go about printing this. Does the printer print plate 1 first then give you time to remove it before printing plate 2? Thanks in advance.
When you click on the icon, you can select which plate you want to print with arrows on screen.
You only get this option if you “send all” to the printer.
thanks for that tip, my issue is each plate I sent to the printer in one project look similar and there is no specific object or file name listed on the print screen. It shows print time and grams and the project name, but not the object printing. Any tips? Does yours do this too?
