3 yr, $4000, over 3400 hr. STILL ASKING FOR A LIVE FLOW ADJUSTMENT
IIRC in the early days of X1C there were comments asking why lidar wasn’t being used to correct flow ratio and bambu said lidar just didn’t have enough resolution to make such small corrections reliably.
As discussed. Flow Dynamics is not Flow Rate/Ratio. Flow rate is how you control under/over extrusion to account for how much volume of plastic is coming out of the nozzle. Flow Dynamics or pressure advance corrects for rapid changes in extrusion rate. They are completely different.
But it would be pretty easy to cover both … Simple for the masses - and advanced for the pros.
With something like … let me think about it … like a Developer Mode? :smiley: I mean a real one, not one where you lose all amenities immediately and are then forced to organise everything yourself via detours. But rather a mode where I can simply set and use MORE, which is of no interest to the masses.
Reading through this I can tell that 1 you either don’t have an H2D or 2 you have no idea what you are talking about.
bumpbumpbump Still need this feature. The more engineering filaments you make the more people need this. So simple. Yet so neglected.
