3D model help
If you were in my situation, how would you get the piece of plexiglass to be one with the 3d printed circle?
Take forever and do a terrible job of sanding down the plexi? Use the zero tools I have that are appropriate to cut the plexi down?
Cut the model in studio and add a negative to slot the plexi into, then add a pause, insert the plexi, and print the rest over it, permanently installing it? Make a ledge in the model for it to sit on somehow?
More or less looking for tips or ideas…unless of course someone wants to do this for me.
Dial Gauge Clock Kit-011 REV1.3mf (995.7 KB)
If sanding it down so it fits in the bore tightly is an acceptable solution, why don’t you just print the ring so it’s slightly bigger and the plexiglass disc fits tightly instead of not at all like in your picture?
Reprinting the ring might take a bit longer, but it’d be a lot less work.
Otherwise, I’d split the ring horizontally and add a notch to both halves that is 1/2 the thickness of the disc (well, just slightly bigger than that to allow for tolerances). Print them both, fit together, the disc will guarantee alignment of the two halves. Run a bead of glue or solvent around the outside seam to lock it all together.
Like this:
I favour this idea.
Insertion
It works for magnets and other insertions. The only issue you must deal with is the likely lack of bonding on the plexiglass.
Some tests will help you with that.
Snap-in basic
You could create something with a tolerance (as already mentioned) that allows the plexiglass to be force-pressed into the base. I would consider having an inner top ring that you push over the top of the plexiglass though, this would give you the same thickness ring above and below the plexiglass.
Snap-in notches
You could instead create a base the plexiglass would snap into by having ridges around the inner top. You then push the plexiglass down into the top with the ridges causing friction until an area of the thickness of the plexiglass is met and it will be stuck under those ridges.
There is no perfect solution. Tests are your friend.
But im so lazy and tests take time.
If the top layer of the negative is 107 and 108 goes back to the smaller diamater of the rest of the ring do i put the pause at 107 or 108?
It depends on if you pull down the top marker or lift the bottom marker.
If you change the colour scheme to filament you should see it occur.
If you drag the top marker down, you see the END of the layer being printed.
In your example, pull down the top and 108.
Huh I had no idea!
Thanks!
And I actually ran a test print. Basically lowered most of the print below the bed so it only printed the area in question. Worked beautifully!
Thanks for all your help!
Somewhat joking/somewhat serious, how important is it to have a nozzle that isnt twisted?
The bottom half of my nozzle is definitely not in line with the top half
I couldn’t see any deformation.
Yeah I couldn’t get a good photo. But it’s definitely twisted
If you are concerned, do not use it.
Minor bending is rarely an issue, but, safety should be considered before everything else.
