3D Printing Thread Definition for Fusion Thread Tool
I created an XML file that can be imported into Autodesk Fusion to make threads for 3D printing available in Fusion’s Thread tool. The threads are made with a 45° angle instead of the standard 30° angle used for Fusion threads, and I adjusted the pitch and diameters and tested printing to make it ideal for 3D printing, at least I think it is ideal. You can’t add a fillet in the Fusion Thread definition file, so I add a fillet after using the Thread tool. I will describe the steps I use for making the fillet later.
A link to the file and instructions on how to import it into Fusion are at the end of this post.
I created the file by first adjusting the parameters in the XML for the following sizes, M5, M10, M30, M50, M100, M500 (many more sizes are available in the file I am providing below). I went back and forth between the file and Fusion until the thread had the best proportions for 3D printing. There are both a tight and loose fitting thread options.
I successfully printed and tested tight and loose samples of the M5, M10, M30 and M50, but I didn’t try printing the M100 and M500.
I then enlisted the help of ChatGPT to interpolate the values to give a wide range of threads. The first time it generated the XML it made some mistakes, but after I pointed out the mistakes, it tried again and interpolated between my threads perfectly. The file has the following Thread sizes.
M5 - M30 every 0.1 mm
M30 - M50 every 0.5mm
M50 - M100 every 1mm
M100 - M500 every 5mm
After importing the XML to the appropriate Fusion location, it will be available the next time you start the Thread tool, you don’t have to restart Fusion.
After starting the Thread tool, make sure “Modeled” is checked, or it doesn’t actually make the thread. Then select Metric 3D Plastic Threads (0.2 LH) from the Thread Type list. The 0.2LH means its for a 0.2mm layer height, but should work fine for other layer heights. For larger than 0.6 or 0.8 nozzle, some of the smallest threads may not be printable because the line width is to large.
If you click the cylinder model that you want to apply the Thread onto, the Thread tool will try to select the appropriate Size, but it is sometimes off a few tenths of a millimeter in the M5 - M30 range. Otherwise you can manually select the thread size in the Size, Designation and Class drop-downs.
In the Class drop-down, you have the option to choose a loose or tight tolerance for the fit of the thread.
After selecting the cylinder and thread settings, click OK to apply the thread.
Here is a close-up of the thread before the fillet is applied.
Open the fillet tool and select all four edges of the the thread. Select the edges, not the faces of the thread or the fillet won’t work as well. (I didn’t add the blue arrows to the images below, Fusion did and they are not always pointing to the right spot)
I try a few fillet values until it is just large enough to completely round the the edges without seeing the lines at the peak or valleys of the thread. The image below shows the lines I am talking about.
I don’t want to fillet any larger than I have to, so there is pretty high precision in the decimal places. In the picture below you can see that the valley is rounded, but the peak still has a line.
Here is the minimum fillet value to completely round it for the M20 thread.
Here is a link to the XML file to import into Fusion. The 0.2LH means its for a 0.2mm layer height, but should work fine for other layer heights.
Metric3DPrintedPlasticThreads0.2LH.xml
Here are the instructions for importing the XML into Fusion.
  1. Allow access to hidden files and directories.
  1. Browse to the following directory and copy the XML file I provided into the folder. The Thread type will be available the next time you start the Thread tool.
Note: Sort by: “Date-created” to find the most recent folder.
Windows:
%localappdata%\Autodesk\webdeploy\Production<version ID>\Fusion\Server\Fusion\Configuration\ThreadData
macOS:
Macintosh HD> Users> [Username] > Library > Application Support > Autodesk > Webdeploy > production > [Version ID] > Then right click “Autodesk Fusion 360” and choose Show Package Contents > Contents > Libraries > Applications > Fusion > Fusion > Server > Fusion > Configuration >ThreadData
A video showing how to find this location in Finder is linked here.
The instructions above are from this Autodesk link.
Importing Custom Thread into Fusion
IMPORTANT: For the Mac location, there will likely be multiple [Version ID] folders. Like shown below:
The right [Version ID] folder to select is the one that contains both the Fusion .app file and the CONFIG, folder, the other ones only contain the Fusion .app file. But if you don’t see it after selecting the Thread tool, you might have to try in the other [Version ID] folders.
If you save an alias to the threads folder, it may not be the right folder in the future. I learned that through my own attempts to make an Alias to the folder.
IMPORTANT: If the thread tool is already open in Fusion when you add the XML file, you have to cancel the Fusion Thread tool and start it again to see Metric 3D Plastic Threads (0.2 LH) in the Thread Type drop down.
This post below instructs how to use ThreadKeeper in Fusion to ensure the thread XML is automatically re-added if you update Fusion.
This works good, I’ve made a few custom threads but lost them because I must’ve skipped a step in macOS (was a rush job). Will give your xml a go :slight_smile:
Thank you very much. This works great.
Unfortunately, you have to repeat the procedure with every Fusion update (at least on MacOS).
Is there a way to install this permanently?
Instead of manually copy of the files to the Fusion360 complicated directories, go into Fusion360 after installing the Threadskeeper plugin and go into “Utilities”. There click on “Threadkeeper”, “Open Threadkeeper Directory”, copy the files there and then press “Sync”.
Anytime Fusion360 updates, threadkeeper will synchronize the files again.
Hope it helps you and others that didn’t know about this plugin :ok_hand:
It’s also compatible with Mac and Windows
Thank you! That was exactly what I needed. Hope it will work as described.
I use and have used it since it came out and yes, it works. As soon as Fusion is updated and you open it, a window will come out saying that “The threads have been added and maybe it’s needed a restart” and that’s it.
Anyway, glad i could help :wink:
Thanks for the info. I will definitely be using that plugin.
It’s not working for me. I am installing on a Mac.
It says the installation was successful, but I can’t find the application anywhere. When I do a filename search for threadkeeper nothing comes up.
Are you using it on a PC?
Just to be sure. The link i gave you is with Windows Installation pre selected. In that page, on the left side, make sure you select the one for your operating system.
Make sure you gave it the correct permissions on mac. I don’t work with mac’s too much. But after installing you find it in the toolbar “Utilities” in fusion360. You can also check the settings in fusion and under plugins see if it’s checked. Last time i installed in a mac, it worked without any problems.
It works, I was just looking in the wrong place. When you said utilities, I thought it was supposed to be in the Mac Utilities folder.
Glad you found it… Now get to work :sweat_smile:
SIM: Really appreciate you taking the time to do this and then create a tutorial for us to follow. This is something I’ve wanted to do but never invested the time. I print alot of threaded parts and assemblies, the piece I just printed fits together Sooooo nicely!
Thanks again!
Semi-related, don’t know if this will provide any better experience but did y’all see that autodesk just added slicing for Bambu lab X and P series to Fusion? Fusion FFF/FDM Slicer supports Bambu Lab printers! - Fusion Blog
@SimEyeSee
Thank you so much for your file and tutorial. I just needed a couple of minutes to create a M8 bolt that works like a charm just after printing
Very impressive and qualitative :+1:
In combination with ThreadKeeper it’s the magic combo :muscle:
Thanks again
JC
Thanks @AeonJoey for the info
Don’t see the interest on that feature when you can open directly Bambu Studio or other slicers like Prusa Slicer from Fusion
And on top of that you’ll have to pay for it if I understood well
Cheers
JC
Slicing is available in the free version of Fusion for personal use, but I cannot think of any reason to use it. It requires a good deal of manual setup to duplicate the presets available included in Studio or OrcaSlicer. Changing a setting usually means looking a couple of menus deep. The g-code produced needs to be post-processed to speak to a Bambu printer and you are left with a file that must then be found and transferred to the printers SDcard.
Even exporting a .step and dragging that into a dedicated slicer is much easier.
Great File… I love it… however I am looking for a particular thread pitch. Any suggestion on how I could create more thread pitches for your file? Thanks
I just saw your post with your Python script for generating thread definitions. Great work!
