Previously I used PrusaSlicer(when I was still owning my Prusa MK3S) and everything was alright but now after I switched to Bambu Lab printer/slicer my .3mf files thumbnails are not shown anymore. I can still see the .stl thumbnails using a Github software but not the .3mf .
Does anybody else have or had the same issue? Any solutions?
I had that already installed on my pc. I can see the .stl thumbnails with no issues but not the .3mf.
I’m got windows 11 by the way.
I’ve also installed Microsoft Power toys. Still not able
I have same issue, I can see STL files, but don’t have full control in preview panel like some seem to, and I can’t use the 3d Viewer to work for 3mf files at all, using windows 11. Some people say have to point to the 3d Viewer but it did not change anything and I still want Bambu to be the default opening software.
Copy and paste the Register Code in a Txt Editor like Notepad.
modify the extension of the file as “.reg”. for example : “Thumbnail-3mf.reg”
Execute, and restart the computer.
Is OK for stl, 3mf… in Win10, Win11
You can add Microsoft Powertoys to see ONLY STL files . (activate the option in Powertoys, Files…
and after, you must execute again the REG file (to see thumbnails of 3MF, stl…
Thanks, this is the part that was missing on my registry:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.3mf]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.3mf\shellex]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.3mf\shellex\{e357fccd-a995-4576-b01f-234630154e96}]
@="{E64164EB-1AE0-4C50-BAEF-A413C2B3A4BC}"
I found this on reddit, it solved my viewing problem
main folder with 3d filed, right click to bring up power shell and paste this
Get-ChildItem -LiteralPath “.” -Recurse -File -ErrorAction SilentlyContinue | Where-Object { -not ($_.Attributes -band [IO.FileAttributes]::Offline) } | Unblock-File -ErrorAction SilentlyContinue
copy past into powershell app for each file folder.
