.4mm vs .6mm nozzle issue after machine reset
Had to do a factory reset. Studio shows when trying to send print: The current nozzle diameter (0.4mm) does not match with the slicing file (0.4mm). Please make sure the nozzle installed matches with settings in printer, then set the corresponding printer preset when slicing.
I have set the nozzle diameter to 0.6mm in the slicer. Pls advise.
Set your printer to 0.6mm, on it’s physical display pad. Settings.
Thanks for the quick reply. Went to settings on the X1c display and do not see a nozzle setting. It shows: print options, AMS options, video, auto-sleep, language, aux part cooling fan, device and serial number, lan only, export log to external storage and restore factory settings. Nothing about nozzle sizes. I do have a .6 mm installed.
Found the nozzle setting. Thanks
