7 x lifespan+High-flow+$49,but manual calibration required. What do you think?
Hi H2 users,
I’m a solo designer working on 3D printing accessories and mods. I’m currently planning a hotend project specifically for the H2 series, and I’d really like to hear your real-world feedback to help refine the product definition.
Current Concept
  • Material: Silicon Carbide (SiC) nozzle (Mohs 9.8) – aiming for 7x+ lifespan compared to standard hardened steel
  • Positioning: High-flow hotend (0.4mm), PLA flow ≥52mm³/s
  • Compatibility: 0.4mm nozzle capable of stable TPU 85A printing
  • Target Price: ~$49
  • Compatibility: Full support across H2D / H2C / H2S / X2D / P2S
The Core Challenge
Since SiC is non-conductive, on H2D/H2C dual-nozzle machines, the eddy current sensor can’t detect the nozzle position – meaning the auto nozzle offset calibration will fail. You’d need to manually disable auto-calibration in Bambu Studio and run a high-precision nozzle offset calibration after each hotend swap.
On single-nozzle machines (P2S, H2S, X2D in single-nozzle mode), this isn’t an issue – it’s plug and play.
A Few Questions for You
1. If a high-flow SiC hotend offered PLA flow ≥52mm³/s, 7x+ wear resistance vs Bambu hardened steel, priced similarly to Bambu’s tungsten carbide, but required manual calibration on H2D/H2C (disable auto XY offset calibration and run high-precision calibration after each swap) – what’s your level of acceptance?
  • □Fully accept – one calibration for 7x lifespan, worth it
  • □Accept with some hesitation – hassle but the performance gain is worth it
  • □Not sure – need to see a video/tutorial first
  • □Not really accept – manual calibration is too much trouble
  • □Not accept at all – would rather stick with stock or a non-calibration option
2. If you chose “not really accept” or “not accept at all”, what’s the main reason? (Select all that apply)
  • □Manual calibration is complicated – worried I might mess it up
  • □Calibration failure could cause offset and waste material
  • □Having to calibrate every time I swap is too annoying
  • □I want a drop-in solution, don’t want to sacrifice automation
  • □I mostly use single-nozzle mode anyway, so dual-nozzle calibration doesn’t matter to me
  • □Other: _______
3. What would make you more willing to accept the manual calibration step?
  • □Detailed written + video tutorial
  • □Simplified calibration process (1–2 steps)
  • □Guaranteed calibration success rate of 95%+
  • □Lower price point
  • □Bonus add-ons (e.g., calibration filament included)
  • □Other: _______
4.Are you satisfied with the current 40 mm³/s flow rate rating of Bambu Lab’s high‑flow hotend for PLA? Would you prefer a higher flow rate, and if so, what would be your expected value?
Please select the option that best applies to you:
  • □ Satisfied, 40 mm³/s is sufficient for my printing needs.
  • □ Fairly satisfied, but a higher flow rate would be better (please specify expected value: ___ mm³/s).
  • □ Not satisfied, would like at least 50 mm³/s.
  • □ Not satisfied, would like at least 60 mm³/s.
  • □ Not satisfied, would like even higher (please specify expected value: ___ mm³/s).
  • □ I do not use PLA or I don’t care about this.
Why I’m Doing This
I’ve been following the community discussions around the E3D DiamondBack – great wear resistance, but ~$150 and not a high-flow design. I see an opportunity here.
If I can deliver SiC material + high-flow + TPU 85A compatibility at ~$49, even with a slight trade-off in automation, I think it could be a solid option for a lot of users.
But that’s just my assumption – that’s exactly why I’m asking you all.
On a single-nozzle machine, the manual-offset problem goes away. That makes it plug-and-play, but it still needs to show a real advantage over Bambu tungsten at the same price.
TPU 85A compatibility is not really a SiC benefit. TPU does not need a harder nozzle. Printing it well comes down to the filament path, hotend design, and extrusion control.
For H2D and H2C owners, giving up automatic nozzle calibration at the same price makes this difficult to justify.
Edit: I realize I compared the standard tungsten price but even for $30 more I can’t see giving up the automatic calibration.
  1. Bambu Tungsten Carbide HF - $59.99 USD
  2. E3D ObXidian 500 - $120.00 USD
  3. Microswiss CHT - $46.95 USD
#1 has native profiles in Studio already, and #2 is about to get the same. #3 uses the existing Studio HF profiles.
I’m also curious about how you plan to achieve your flow benchmarks and your TPU compatibility without infringing any current patents.
My strategy is to go for a higher flow rate.
I think this really depends on who you ask.
If there are people here with a print farm and running the same nozzles continuously, you have your target audience.
The users that want the best of the best are an interesting group also.
Most hobbyists might settle for a tungsten carbide or even a hardened nozzle as a reasonable alternative if wear resistant is key.
As I am more of a hobbyist and not really interested in fast printing, I currently settle for my TC nozzle. They handle my Engineering projects fine and I have not needed a new set yet.
But to answer your questions:
  • □Other: Takes too much manual time
  • □Other: Not really anything
  • □ I do not use a High Flow nozzle!
SiC has a very good non-stick behavior which is in general great for materials like PETG and TPU.
But that same characteristic also reduces the flow resistance, and therefore reducing the back pressure in the nozzle, which is quite important for TPU printing.
Thanks for your response.:grinning_face:
a solution looking for a problem
Every nozzle I’ve destroyed in recent history has been from bent/crashing, not from clogging or excessive worn-down-from-use. (Edit, thinking back, I rotate them at 5k hours so y’know, I guess I do replace on wear but not due to observed problems) I dont think nozzles tend to die that way anymore, so hardness being the focus is slightly meh.
Advertising high flowrate AND tpu together seems counterintuitive to how those materials behave in a printer. I’d be shocked if you could do that without also an extruder replacement/assist/special materials. Others have tried, and settled on higher diameter filament [iirc, 2.1mm?] being the single most important variable, to make the requisite pressure not cause flexing in the tiny open space following the extruder. Any deflection there is a Bad Time©
People owning a print farm and printing 24/7 abrasive (and don’t underestimate Glow in the Dark) filaments will not totally agree with you.
The low friction and non-stick behavior of SiC and Diamond is having a lot of positive effects also.
As I mentioned also, most hobbyists probably don’t care.
Not looking for a problem, as the problem is well described (as are the advantages).
The OP is looking for opinions.
and hes received them.
25252525
Not from you!
There is also the E3D/Diamondback nozzle, they dont have a high flow variant yet but Im sure they will eventually. What benefit would SiC have over diamond? Diamond is harder and also non stick with great thermal conductivity.
I print a lot of CF filament and you print those engineering filament pretty slow, so people that need the wear resistance dont really need the speed. I still use HF nozzle for better layer adhesion but I dont push the speeds.
Personally Ive been using the bambu OEM tungsten HF nozzles, and have not felt the need to buy a diamond one. Maybe to reduce filament buildup with PETG would be the only reason.
However if you modified an H2C Vortek nozzle with SiC tip I would be all over it.
