H there,
strange problem: I got the message: A G-code path goes beyond plate boundaries. “Jump to” after slicing a buildplate. But the problem is, if I try to click on “Jump to”. It just doesn’t work. As the plate is quiet full (try to print the tank from Makerworld ) I just don’t know how to solve the problem…?
Does anyone have an idea how to find out where the problem is?
greetings kuhni
I think I’ve had that happen because brims ended up crossing plate borders (which should be a bug, but then I think it’s intermittent). Did you try auto arrange with a spacing of 0.2 mm or so?
Void
April 11, 2024, 9:20pm
3
i can’t believe this hasn’t been fixed… the problem area needs to be highlighted, at the very least
opened 12:17PM - 12 Dec 23 UTC
bug
backend
### Bambu Studio Version
1.7.7.89
### Where is the application from?
Ba… mbu Lab Official website
### OS version
Windows 11
### Additional system information
Processor: 12th gen intel core i7-12700H
RAM: 16GB
### Printer
Bambu Lab P1P
### How to reproduce
1. Align many objects with the align option. Settings used: Spacing 1.35, Auto rotate on, Allow multiple materials on,. Align to Y axis off. Press Align. The 3mf project I have done these steps with is attached further below.
2. Slice Plate. The Print plate button is green, click the button. Nothing is sent to the printer.
3. Select Preview mode. Here it shows there is an error with the Gcode generating a path outside the build area. Pressing "Jump to" will not do anything, so I can't find the problem area. Also, the auto-align feature should not cause this in the first place.
4. This results in that I cannot print using auto-align, or even fix this manually. For production this needs to be printed in one go and manual alignment is not doable for this many parts with so little spare space, especially because it is not clear where it thinks it is going outside of the build area. This bug prevents me from printing models like these.
### Actual results
Using auto-align parts, I get the error on Gcode outside of build area as in the screenshot above, and it won't let me print.
### Expected results
- The align feature should make sure it only generates gcode inside of the built area.
- If Gcode is generated outside of the build area, the Jump to problem link should work and show me exactly which part is going outside of the build volume
- The print button should not show green if there is an error that prevents it from printing. It should also clearly state in an error message showing in organize mode (not only preview mode) that there is an error that prevents from printing.
### Project file & Debug log uploads
[AllPartsOnBuildPlate.zip](https://github.com/bambulab/BambuStudio/files/13647893/AllPartsOnBuildPlate.zip)
[log.zip](https://github.com/bambulab/BambuStudio/files/13647957/log.zip)
### Checklist of files to include
- [X] Log file
- [X] Project file
My model takes a good 10 minutes to slice… i’ve been tweaking and slicing/praying for the last three hours
