A hole in a wall of my print appearing regularly
I’m printing from PETG. Dry as straw. During print I noticed that there is a hole in my print on one of it’s faces.
The shape is absolutely basic. Printed with 0.24mm layer and 3 wall perimeters, enough to cover inside.
It appeared about 5h:40m/6h:46m of my print. Once it finished i took it out, cleaned plate, cleaned nozzle and started it again.
On next print exactly same thing in exact same spot, exactly same element in same orientation. Only sooner, about 3h:10m/6h:46m.
It’s not a a seam, i have it aligned elsewhere. I checked slicer and gcode preview and there is nothing suspicious there.
Beside that there were no other print issues. No stringing. Perfect bed adhesion.
Have you tried using the vertical slider in the slicer to look at the layer(s) where the defect appears? When you are at that layer use the horizontal slicer or the left/right <> keys to watch the path of the tool head.
Yes I tried. I haven’t noticed any artifacts there or suspicious mesh glitches. This is how it looks like after slicing. Red X’s indicated defects during first print and subsequent print.
Cross-section for whole part looks like this
If you haven’t yet, check it using the different coloring options in the slicer preview (selector at upper right in the slice details window). Especially print and fan speeds.
Also check tool path to see if the nozzle is entering or exiting at those points.
Is there anything inside those holes at the affected layers?
Sometimes anomalies can be caused by transitions between walled and filled areas. Something like that may be revealed by the aforementioned coloring views.
Looks odd though, more like an extrusion “glitch” in those spots, like pressure advance got thrown off or some physical contact occurred. It’s hard to tell from the photos (and sometimes in general) if the imperfection was on one layer, and the rest are covering for that, or if something happened repeatedly on the affected layers at that spot (the former being more likely).
Do you have timelapse imaging enabled and if so, which mode?
-Max
