Just putting this out there but while working with my poly cereal boxes, I put a spool of fresh PETG HF from its poly bag into a cereal box without a desiccant pack and was surprised to see the humidity in the poly box start climbing up.
Just checked this morning and ambient humidity in the room is 39%, the spool of PETG HF in a poly container is showing 42%, and a spool of ASA that I had dried for a few hours yesterday is showing 25% RH in a poly cereal box. Again, no desiccant to scavenge out water.
I think poly boxes without desiccant might be a way to get a handle on water content in filament by putting a spool in a poly container with a hygrometer, closing it up, and let it equilibrate to a stable humidity reading. The humidity should be a function of water content in the filament and may get skewed with cardboard hubs and spools but still should give an idea of how wet the filament is.
I doubt you can directly compare moisture contents from one filament type to another but within a family like PLA, you can probably say if one spool is wetter than another and people may be able to find humidity levels that predict if there will be printing issues or not.
We don’t have a way to determine actual water content in a filament but this might be a way to indirectly measure water content without having to dry to get a weight change, etc. Everything else has been a change - how much water was lost and so on but nothing to actually get a handle on water content. This might give a number related to actual water content.
