A request for Bambu - The green door
Could you please consider making an upgraded door, to give the same visibility as the side panels.
It’s my only request for this awesome machine.
I don’t want to swap the door to clear as many are.
But I did notice the side windows look fine for visibility.
The front door is two layers of green material. Makes it’s much less visible.
How about a glass door with a single thinner (as per side panels) layer adhered to it.
It’s actually more important that you think, not being able to see in without using the camera or opening the door, need a solution please :slight_smile:
Look forward to seeing what their R&D department come out with in the future.
Will add photos of side vs front visibility on a new un-used machine later.
You have a laser operating in the visible light spectrum and want a see through door to get a better view of it in action?
Might be easier to just drip acid into your eyes or to use a soldering iron to cauterise them…
The green is basically the opposite of the blue laser light - next to nothing makes it through and being acrylic also blocks the remaining invisible light that is emitted.
You NEED the right protection for a laser if you value your eye sight, especially if playing with the 40W version…
Go ahead and check what’s available in terms of protective goggles - that is the minimum required for a front panel…
And considering that it makes no difference - protective goggles or a protecting door.
I do agree though that a a removable panel or quick release door should be included if you buy this thing with a laser…
But that also makes it invalid for EU use and probably US use as well - there is minimum requirements for the laser safety and I guess that is the main consideration for Bambu - they can control what you get but not what you make out of it…
Here is a photo taken through the side and front door. New machine just un boxed. Freshly peeled glass protection.
Side, good clarity:
Front, much less visibility. Could easily be engineered to match the side views. They have used two layers of green Perspex, to get the door strength required no doubt. A glass door with a protective inner layer the same thickness as the sides would give the same visibility as the side and a stronger / higher quality door feel.
I see everything just fine knowing the importance of the safety behind it. Darwinism will always be alive and well…
We are in agreement, do not remove the green door.
Improve the visibility is the goal here. For printing and laser operations, visibility is also a safety factor.
Side windows are safe and visibility is markedly better. Apply this solution to the front door, with engineering to solve the flexibility.
I have wondered why the side windows are nice and clear while the front door is foggy. I personally don’t plan on using the laser much, if at all, so I swapped my door for the glass one. If it was clear like the side windows I probably would have left it alone. Maybe it’s foggy by design? More protection through the window we will be looking through 99% of the time.
If I ever need to do laser stuff I’ll swap the green door back on. Takes 30 seconds. The laser won’t operate if the green door isn’t on so there’s really no risk of “forgetting” to put the proper one back on.
the front door is a moving part and it’s large, so it’s made by acrylic to make it cheap and also less vulnerable to breaking. Large, laser filtering hardened glass would be much more expensive
You’re not wrong, it’s terrible for using as a 3D printer - like looking at my prints through green milk. And yes, the sides are fine. I’m swapping doors but would love a better option.
We all know there’s no safety risk, and it has multiple interlocks, but stand by for all of the wailing from the safety patrol…
I’m going to swap mine anyway, since bambu does have pretty strict interlocks to prevent a mistake from happening for laser.
Green and black is a good look… :slight_smile:
I totally get the frustration with the dark front door. I’d love to see a single-tinted glass option from R&D too, keeping the view clear like the side panels.
I missed this old thread when it first went around but
Hopefully they didn’t do any swaps. Just getting green plexi is no guarantee it is safe with the laser. It takes instrumentation these guys won’t have to know if some piece of glass or plexi is safe to use with a particular laser wavelength.
The plexi can look the same yet still let damaging radiation through. Interlocks have nothing at all to do with whether side glass or a door are unsafe for blocking laser radiation unless they are somehow keyed for the OEM door and detect unauthorized swaps.
I hope nobody followed these unwise folks in their misadventures. Some of the most unsafe posts I’ve seen here.
Wonder if they have had any eye exams since they did this stuff and what their retinas look like.
Easy fix. Just turn it sideways. :zany_face:
You only get one pair of eyes.
Just a clarification:
Switching the door to normal version only allows you to do 3d printing. You won’t be able to do laser because the doors are different and the normal door doesn’t have the magnet to trigger a hall effect sensor. The sensor is used to make sure that you’ve shut the green door for laser. The firmware enforces this security check.
It’s good Bambu went the extra mile to help keep the industrious from defeating the interlocks. Only thing is swapping out parts intended to protect users erodes protections.
In just about every accident there is a chain of events that leads to an accident. Safety steps are skipped, protections are removed, procedures get modified. And each one of those and others helps the holes line up.
The consequences of this can be severe. Or not. It all depends. Some may treat these mods with respect and others may not. You guys do what you want. People should know that each protection that gets defeated moves them closer to an accident, though.
