A1 AMS Lite Filament misaligned and not feeding into the nozzle
Hi everyone,
I am having an issue where the filament does not extrude straight. There is a slight offset/misalignment, which prevents it from entering the nozzle properly.
  • The nozzle is clean and thoroughly maintained.
  • When I manually push the filament into the nozzle, it works and extrudes, but it doesn’t feed automatically on its own.
A few questions:
  1. Should I disassemble the extruder? I recently printed with PETG-CF, so there might be debris or wear inside.
  2. Should I print/design a custom guide part using the two screw holes to help align and guide the filament?
Thanks a lot for your help!
There should be a guide part already there where you have coloured in blue
did you buy your A1 used ??
you can print one ive found here but u will need the screws
Yup, you’re definitely missing a part OP.
ah yes it should be somewhere around
thanks ^^
