Can we put the ams of the x1c on the A1 that would be cool ? Thanks
No, you can’t use the AMS Light on the X1 and P1 Series, nor use the Normal AMS on the A1 Series.
No you can’t currently mix AMS types across the printer ranges.
BL could i think fairly easily make software changes to allow X1/P1 AMSs to work on A1s.
The other way around would be less likely as for the X1C or P1S the top lid would get in the way of the 4 tubes - so some sort of riser would be needed. Plus also the extra weight of the splitter and 4 tubes would probably adversely affect print speeds.
I have a X1C with two AMS and a A1-Mini without AMS, so i was wondering if there are news about this or ist it still impossible to connect a normal AMS to the A1 mini…? Maybe any Workaround or hack…?
