A1 Bad first layers.. the struggle and solution
Just wanted to share the learning that i am sure someone experienced already has. I have been trying to print a large print… almost full width. and my first layers were struggling . wouldnt outline properly. it seem like adhesion was an issue. seemed like the hot end was rubbing the print…
i tried everything. from cleaning the plate. from slowing down the first layers speed super slow. replaced the hot end. everything … prayer. exorcisms…
the solution. YOU MUST PUT THE PLATE ON PERFECTLY. Perfect placement of the plate on the machine. the slightest of issues… and all the above happened to me…
Look for the tabs on the front. make sure you can see the white of the bed on each side… this needs to be perfect.
Anyway… i am rocking. the plate must be perfectly level now … even if it looked like it… and by the way… i was making small prints successfully as i was going through it… but the plate must have been level enough for those.
