I’ve been struggling for about couple month with my Bambu Lab A1 printing architectural scale models and I need some honest feedback from people with experience.
Context:
I work for an architecture firm. We use ArchiCAD to design houses and export them as STL files to Bambu Studio. We print scale models at 1:100. The models are simple geometry — no fine details, just flat walls, flat floors, and rectangular window/door openings. The final model will be painted so finish quality doesn’t need to be perfect, just straight and flat.
Divided the house into sections (first floor walls, second floor walls, roof printed separately)
Printed the floor plate at 45 degrees on the bed
Glue stick on the PEI plate textured for bed adhesion
No fan for the first 4 layers
Brim ears around every piece
Fixed all geometry issues in ArchiCAD (no more holes or missing faces in the export)
Remaining problem:
All walls warp and curve, especially at the corners. The floors lift at the edges. The walls lose straightness as they get taller due to bed vibration.
Wall thickness at 1:100 scale:
Exterior walls = 3mm printed
Interior walls = 1.8mm printed (these are inside so less critical)
Two specific questions:
Would switching from Bambu Matte PLA to regular white PLA make a significant difference for warping on thin walls like this?
Is the A1 bed slinger fundamentally the wrong tool for this type of model at 1:100 scale, or is there a setting/workflow we are missing?
We have until Black Friday to decide whether to upgrade to the another 3Dprint. I want to make sure we have exhausted every option on the A1 before making that recommendation to my boss.
Any advice from people who print architectural models would be really appreciated. Thanks.
Pics would really help, there’s a lot to unpack here that could be legit model problems or usage problems or material problems:
IMO Matte is more finicky and less reliable than standard PLA but I know I am fairly alone in that opinion, so I would say yes, use literally anything else.
The only thing a bedslinger is the wrong tool for is : tall things with a bad base connection to the plate. To fit your architectural motif, the eifel towel would be good since despite height it has a strong wide base. A boxy skyscraper would not be a good choice since it will just wag around on Y movement and get knocked off eventually. With no pics, its impossible to give good feedback on.
Even still, back in the ender days, we got around bedslinger motion problems by just reducing acceleration and jerk of the print, so it doesn’t waggle. Sure its a few more hours, but make another cup of tea and itll be ready.
Not being enclosed is probably a big one. You can always put a cardboard box or similar around it for better temperature control.
I’d use liquid glue on textured PEI. If you don’t have it, you can make it from stick with some water or IPA/water mix.
In that wiki they discuss infill – wall thickness is also a factor.
You could also try things like mouse ears or brims to help hold the corners down. There are also ways to add model features that relieve some of the stress that’s peeling the corners up.
And one of the things that caused corner lifting for me was too high of filament moisture content. The corner lifting also led to top surface scarring above the lifting corners. If not familiar with drying, might check the Bambu wiki:
I’ll come back later tonight to look thru those settings, but from those pics my gut reaction is: “Get a cool plate and use a different filament”
Lots of sharp corners and stressors that your design is gonna be stuck with. Cool plate helps fight edge warping by holding the print in the “solidified” side of the glass transition temps. Overall the material is seen wanting to contract - warping on the bottom corners -and- the benchy hull line on the roofline. Maybe its running too fast? This is also the sorta warping thing that a GF/CF filament can stabilize.
I don’t have any open frame printers anymore, but one thing catches my eye: The bed temperature is pretty high at 65°C for PLA, it can stay soft at that temp.
I would double check the plate is absolutely clean (there is a good article here on how to do that) and start over with Bambu Standard settings.
That’s bed adhesion failure and material shrinkage happening.
If you’re printing your walls solid, that’s a problem. Two outer walls and infill is far better. Look into protecting your build environment from air drafts - even a big cardboard box over the whole printer would be helpful.
Make sure your filament is very dry. Textured PLA isn’t the greatest option for your build plate, something like a cryogrip, supertak, or some of the Darkmoon plates would be far better. Cleaning properly is crucial - dish soap, nylon scrub brush, hot water, dry with paper towel. Look into Vision Miner NPA. Lastly, you may want to look into printing on a raft.
PLA likes the 30-35°C range. Not easily achievable with an A1, but getting closer to the range can help.
You may also want to go back to default settings. Printing at lower nozzle temps is usually more trouble than its worth.
Better to even out cooling by slowing down and/or halving the layer height. I have only ever seen the need for the latter with exactly 2 PLA problem descriptions in the forum or with PETG (and beyond).
Looking back at your photos, this one might be handy too. There are some tell-tale defects at the bottoms of doorways and windows that this might help too.
Thank you, this is very helpful. I will try dropping the bed to 55°C after the first layer and adding a draft shield. Quick question — what do you mean by dropping walls to 2? Do you mean wall loops from 3 to 2 in the Strength tab? And for the draft shield, is that a setting directly in Bambu Studio or do I need to model it separately?
Thank you. The room is air conditioned so it’s probably around 20-22°C. I will try the draft shield and going back to default settings. Should I also try drying the filament first before anything else since it has been sitting open for about a month?
Thank you. I am currently using 3 wall loops with 15% infill, not solid walls. I will try dropping to 2 wall loops. I will also add a cardboard box around the printer and dry the filament first since it has been sitting open for about a month. I already have a textured PEI plate — is the raft enough to compensate or should I really consider a different plate like the ones you mentioned?
Thank you, I appreciate you coming back to look at the settings. Yes please, any detailed feedback on the settings would be very helpful. To answer your questions — I am already running the outer wall at 200mm/s, do you think that is too fast for this type of model? Also what filament would you recommend instead of Matte PLA? And what is GF/CF filament — is that something easy to use on an A1?
Very hard to say, way too many variables at play here.
I’d make all the other changes and try again with an immaculately clean build plate, then add a raft/brims if needed, then if needed look at a higher performing plate and/or glue.
I also want to mention that I am considering upgrading to the X2D combo before Black Friday. From what I understand it would solve several of our problems at once: the enclosed heated chamber eliminates temperature variation, the CoreXY means no bed movement on the model, and the enclosed environment protects the filament from moisture during printing. Does anyone have experience with the X2D for this type of architectural model work?
Yes, always dry the filament first before doing anything else. Having spent weeks at sea, it is frequently moist straight from the bag so if nothing else, drying it will at least rule moisture out. Your pics also strongly suggest that moisture is an issue in this case.
The 20-22°C should be OK’ish with dry filament as long as you can rule out drafts. Best protect the printer rather than printing a draft shield though. A draft shield has a tough time against the mass of air coming through an open door for example…
And maybe try without the a/c in that room. When I ran my first PETG trials on an open printer about a decade ago, I told my wife that I hadn’t figured out the new heating system. She started wondering at 28°C
PS: For build plate adhesion, keep in mind that you need to get the grime out of the tectured PEI’s grooves. So a clean, stiff brush can help a lot in conjunction with a lot of water and dishwashing liquid. Best do that several times in a row.
