Could I bring a a1 camp is there any particular issues? And I don’t know to much about to a1 is there a good way to transport it
If you mean “can I travel with my a1 without causing it damage?”
Yes.
Consider it a small child when packing it into the vehicle. I would recommend wrapping a towel of similar around the body, making sure to hold the build plate in place. I would then consider wrapping some tape around that, not too tight to break things, but enough to stop the build plate moving.
Consider having the back and forth direction of the build plate at 90º in the car. This will reduce any unintended movements during breaking and decelerating.
The mains points is, make sure things that wouldn’t move when on a flat surface wouldn’t move when in motion.
I assume the camp will have power. It is possible to run the printer in a moving vehicle if you are careful and have a mains outlet available. I wouldn’t recommend it as the unforeseen can happen, but there are many YouTube videos of people doing it.
Yes I would be running it stationary in a campground with sufficient power to run it also I loved you calling a small kid lol
Glad I could help.
