A1 Coliding at HoneyComb model
I’m having issue o print this model.
After 66 layers the nozzle colides into a part of the print.
Already calibrated, tightened screws… and have no lucky
https://makerworld.com/en/models/1763853-2-in-3-in-post-it-note-holder#profileId-1876765
IMG_4421
I’m guessing the model’s creator made a mistake when uploading the print profile and forgot to optimize it. It’s simply set to the 0.2 default profile without any adjustments:
That might work, or it might not. Especially with such a complex pattern, at least some optimization would be advisable. As an initial step, I would use a high-quality profile as a base.
If you hover your mouse over the entry, you’ll even get a detailed explanation:
I think in your case, it’s simply the most obvious explanation: The creator forgot to optimize the settings. That’s probably why this model has so many prints but very few ratings - and no boosts yet, which is highly unusual. That could - but doesn’t necessarily - indicate that others had problems as well.
Why don’t you try a model that shows real pictures in the comments and provides proof prints?
When I search, I find hundreds of models with confirmed successful prints:
High Quality does not work. 0.28 extra draft did the job…
That’s really strange. Didn’t you try the many tips in the other thread that you posted in a week ago?
All in all, I think you’ll probably need to provide more information so folks here can help you in a more targeted way - more feedback on what you have and haven’t tried.
