A1 duplicates files when printing
I am having a weird issue with my A1 that I never experienced with my X1C. I am on the latest firmware and version of Bambu Studio. When I slide a file, then send it to my printer thought Bambu Studio, then go to the printer and select it and print it, it creates a duplicate file. The original file, for example, id Darksaber Blade.gcode.3mf. The new file is Darksaber_Blade_plate_1.gcode. Is. there some setting I’m missing that’s different with the A1 to prevent this from happening? The duplicate files really fill up the small screen and make scrolling through for files annoying.
Hello,
I have the same problem as you.
Did you find a solution ?
I have not found a solution, unfortunately. Right now I am just dealing with it, which is pretty annoying seeing that the screen can only show 4 files at a time.
After updating my A1 Mini, the file duplication issue has become even more frustrating. Previously, only 3MF files were duplicated, but now G-code files are as well.
I often reprint my files, and it’s convenient to start a new print directly from the printer after removing the previous part. I specifically used G-code files to avoid duplication, but now they are also affected. This is very disappointing.
So dumb that this is still a thing. Why show the duplicate files? Is anyone at Bambu actually using an A1? I guess you can’t make your low end machine TOO good or otherwise we wont upgrade at some point because of little annoyances like that.
