A1 FIRMWARE: 01.01.01.00
AMS FIRMWARE: 00.00.07.89
DESCRIPTION:
I’m having loading issues with the AMS lite and I tried three different senarios. One that suprisingly loads successfully. It doesn’t fully fix my main issue, but thought this one was interesting enough to post. This issue occurs on all AMS slots.
THE SETUP:
Attached is a picture of my setup. I have a filament piece in the AMS slot to simulate a filament roll that needs to be loaded in. Then I’m hand loading in the filament piece throught the filament sensor and into the tool head.
I have no clogs or blockage in the hotend/toolhead, and my extruder gear and tension gear are aligned.
SENARIO 1: Do nothing and let the filament load on it’s own (FAILED)
SENARIO 2: Push the filament into the filament sensor directly from behind the filament sensor (FAILED)
SENARIO 3: Pushed the filament piece through the AMS that’s not attached to the filament sticking out of the AMS (SUCCESS)
Any idea what’s going on here? Seems like the AMS might be the issue some how? I tried the other AMS slot and the problem persists. This issue started on JAN 14 exactly a 30 days after I bought it.
