A1 Hard footpads - Replace Tape
Hello everyone,
I would like to ask if you know what double sided tape to use (especially thickness) for the hard feet (these) that are on the main frame of the A1.
The reason for the question is that one of them has started to peel and shift during printing so I want to replace the tape holding it.
BambuLab only sells the edge anti-vibration as a replacement part.
Thank you all for the advice
Replace them all and use 3M (scotch) VHB tape - stands for Very High Bond.
The stuff even sticks to milk bottles.
Even a small roll costs quite a few bucks but if you check online you can often find them as just pads in various sizes.
Once applied onto a clean surface you won’t even have a chance to re-align things so yes, it is great sticky tape…
Thank you for your reply.
I have ordered two types of 3M tape, VHB RED 5915 and 9495LE. When they arrive, I will test both two and stay with the better one.
I will let you know.
Too bad these hard feet are not sold by BambuLab as replacement parts.
I ended up using 3M 9495LE. It was similar to the original and held up well.
