Today while doing a cursory check on things I pulled the hotend off my A1 to have a look at it. When I did I discovered that the glue holding the magnet in place on the hotend had broken loose and the magnet stayed behind.
Any suggestions for a really good quality glue to use to reattach it. I know any thermal glue should work, but the particular one that’s on it now obviously didn’t.
If it’s any consolation the same thing happened on both my X1Cs that I print ABS on. Here’s what I used, if the reported operating range is correct it’s insane: Operating Temperature Range: -650 to 1800F (-540 to 820C)
The operating temperature rating shown on the Super Glue website for that particular product is incorrect. Whoever typed the info for the website added a zero to the end of each temperature. That is proven when you do the temperature conversions from Fahrenheit to Celsius. it states that it is rated for temperatures -650 to 1800F (-540 to 820C). Those temperatures actually convert to -650F = -378C and 1800F = 982C. If you remove the last zero from each temperature, then the actual operating temperatures for the Super Glue original formula gel is: -65 to 180F (-54C to 82C), which is correct. I sent an email to Super Glue to advise them of the error on their webpage.
I am going to try a different adhesive, JB Weld temperature resistant metallic paste. It has a continuous high temperature rating of 1000°F / 537°C. I will reply back here with the results.
