A1 mini extruder on back side of cutter
For some reason the extruder is on the wrong side of the cutter and I can’t figure out why.
That does happen sometimes if there is leftover filament there from a previous print.
Also, there also was an update about 3 months or so back to fix a similar issue that an update caused…are you up to date…??
It’s up to date, I ran calibration yesterday and again today. I don’t see anything stuck on there, but I’ll adjust the axis up to get a better look or maybe pull the extruder out.
Once I got the rubber boot off I could see the build up and it was exactly the color I expected. I had issues printing a dart blaster part out in 100% infill with the black. It printed ok in red with a few cosmetic errors (internal parts, who cares) But every print since then has had small cosmetic errors. Cleaned it all off with a pic, recalibrated then loaded and unloaded each filament to verify and recalibrating again now to be safe. Guessing the black might need some tweaking with temp or something.
Thank you
