Anyone have a suggestion on what may be causing this? It happens on the first layer but also on other layer. I’ve tried 2 different CLEAN plates. Changed the extruder gear, 3 different hotends ( 2 .04 hotends and 1 .06) tried running flow test as you can see, i got one to finish and it direct me to change my flow setting from.98 to .745. A big jump. I’ve tried adjusting flow up and down from. .74 to 1.0 just to get through the test. Nothing really helps. I’m beginning to think it’s the stepper motor ( very uncommon I know).
The last picture is after I trammed the bed.
ciao! secondo me il problema e che il piatto é sporco oppure l’ugello non é fissato bene e cio causa dei micromovimenti. per risolvere innanzitutto ti consiglio di lavare il piatto con acqua calda e detersivo per i i piatti sgrassante. se cosi non risolvi allora controllerei il nozzle se é messo bene.
