After 2800 hrs on my 1yo A1 mini I got myself a sizeable blob. Yes, I’m the one to blame.
I’m 2/3 done cleaning the PLA off, following the official wiki.
I’m at a point where I wonder if some parts need to be replaced or just cleaned some more.
What’s done:
Removed Part Fan + dremeled off all PLA blob. Looks fine to me.
Moved Hotend Cooling Fan to the side (no damage). I will remove it completely before I finish the clean up to avoid damage from heatgun.
Heated then removed the Nozzle and wiped most of PLA off, but after putting it back to reheat it (oops) I found out it would no longer heat up.
I noticed 4 clipped wires (see pictures) that look like
- the Hotend Heating Assembly (2 wires in clear plastic)
- the Eddy sensor wire (2 bare copper wires).
From what I read the Eddy sensor only comes with the Extruder Unit, so this probably needs to be replaced.
I once had to tighten bolts on the back of my Hotend Heating Assembly, so it might be possible to resolder the wires back on.
Replacement parts I already have:
* Extruder Unit
* Part Cooling Fan
* Hotend Heating Assembly
* Hotend Cooling Fan
* Filament Sensor + Base
I could swap the Extruder Unit + Hotend Heating Assembly and try to fix those while my A1 mini is back to work (unless I missed another issue).
I’ve fixed a lot of stuff so I know it’s time to seek input from more experienced users. I would appreciate if someone could please tell me which part should be replaced and the best course of action.
Thanks.
