A1 Mini no longer printing
My printer has stopped printing. When I try to print, it gets stuck on bed leveling. When I try to calibrate, it gets stuck on home all axis.
I have reset the printer, downgraded, then re-upgraded.
The printer is heating up to the right temperatures but will not print anything.
No filament is stuck in the printer.
Have you tried using a different SD card yet?
I tried taking the SD card out and printing.
And still had the same issues
Suggest logging a support ticket.
Welcome to the forum.
I will send in a support ticket. Thank you!
By reset do you mean factory reset or just turn it off/on again?
i think factory reset is it the z axis when you said that it was stuck my frist one had the same issue did your z axis had a stange sound if yours is the a1 lubricate the z axis scew rod if yours is a1 mini go to the wiki
I did a factory reset and even downgraded the printer and reupdated it. Still no fix. I think there might be a short somewhere. It acts like it is going to home but then just freezes
Hi, was it solved ? I have the same situation when trying to initiate calibration of my new A1
my A1 mini canonot connect to wifi my wifi dosent show up in wifi list
