This label pealed off of the print head assembly. Where can I purchase a replacement or is there a print model that can be glue in its place.
Thanks,
Bill
Thanks,
Bill
That’s off the parts cooling fan.
Mine came loose about 3 months of printing. I was going to pull it off until I saw the fan wires underneath. I just glued it back on & it’s been fine.
The new cooling fans don’t have a sticker, it’s imprinted on.
What glue did you use? I was concerned about heat causing the glue not to hold.
Thanks,
Bill
Mine came off where the red line is. I put a drop of super glue on the label where the blue dot is. It’s lasted about 7 months so far.
I opened a ticket to see if I can get another sticker since this one is a little mangled. They did reply within 24 hours and said they do not have the stickers and to glue or tape it back on. Not the best solution but it is what it is.
Thanks for your replies.
Bill
Same sticker problem here.
I wish they did away with this and other stickers on their printers.
As soon as they peel off (and they always do), it makes the printer look bad.
