A1 Mini Stopped because nozzle temperature problem
I got my printer and after I finished setting it up I saw that when it tries to calibrate it throws this error: Printing Stopped because nozzle temperature problem. [0300-8008 112002] I have factory reset but that is about it.
Welcome to the forum! Is the silicone sock on? Try taking the quick change nozzle out and putting it back in.
just tried that but didn’t work sadly
If you just set the temp on the screen does it heat up to what you set it to or does that cause an error too?
it causes an error and the screen just says 0
Nonstop Nozzle Temperature Error: 0300 8008 - Bambu Lab P1 Series / Troubleshooting - Bambu Lab Community Forum
A1 Series Hotend Heating Assembly Replacement Guide | Bambu Lab Wiki
Although you really should contact tech support and supply a log file
Mine will heat up to about 135C and then begin decreasing temp
Welcome to the forum! Any error messages? Does it do the same when you try to print something and if you just set it manually from the screen/Studio/Handy?
Click “Assistant” to scan the QR code at the time of the malfunction, and then find the solution.
