A1 mini stuck after try to update to new firm
Hello, I ask because I push button in screen to update to new firm 01.02.00.00 and it starts normally but it stops at 62% and after that the printer ask me to restart and reupdate, but I tried at least 40 times and always stop at 0% and gives the same error…
I cannot use the A1 mini because it is in a strange state, for example nozzle temp when I turn printer on starts on 10ºC and after 5 seconds it comes to 0ºC (my room is about 20ºC ambient temp)…
I tried a lot of things without success such as:
  • Try the option that appears 10 seconds after turn on the printer of “Repair” firmware, but does do nothing
  • Try to update from Handy app
  • Try to update from Bambu Studio
  • Try to update from Handy app, screen and Bambu Studio with AMS lite disconnected
  • Try to downgrade firm from Handy app (nothings appear there to choose)
  • Try to activate Beta Program, but no firm appears different from 01.02.00.00
  • Format the SD card from printer screen
  • Changed the SD for a brand new Samsung and formatting it
  • Try a factory reset in the printer
  • Connect it to several different WiFis
Nothing works of that options :frowning:
I am waiting for the answer to a ticket but I put 4 days ago and still not received nothing, I ask you because perhaps someone knows some more to try, many thanks to all :slight_smile:
try unplugging it and plugging it back in again.
I’m being serious btw, unplugging it for 30 seconds will allow the power outage progress save capacitors to empty, effectively inducing a hard reset on the printer.
if that doesnt work try these: connect to a different device with the latest software, then the previous software. force the update from the slicer, downgrading your version, then upgrading with both updates. leave the printer be for a while to do it’s own thing. upload the update onto the sd card and physically put it into the printer (printers are very finicky with this option, the likelyhood of it succeeding is second to none, but it worked once for me.)
Hi, thanks for these ideas, I try to unplug all night too but no work…
i would go with the best course of action , you`ve already chosen, Patience
had the same problem, i made a hotspot with my phone and connected the printer to it and made the update
maybe it works also for you
regards
Hi! I try too the connection to wifi hotspot of an iPhone but no works… I think in my case it breaks the update when the new firmware is almost writing and because that I have a strange firm mix of old and new… Thanks for try to help! :slight_smile:
I have same error,update my a1mini stop at 32%,espariz your problem is fix?
Hi, still no answer to my ticket… I tried a lot of thing but now 5 days without printer :frowning:
I can´t complete the update and printer is in a strange state, I cannot print… (for example nozzle temp is at 0ºC when ambient temp in room is 20ºC)
If you find something please tell me thank you very much!
Did you put a ticket too?
Hi, I am desperate :frowning: 11 days without any answer to my ticket, please give me some idea I can test, I tried almost 200 times or more in a lot of ways to repair or update my firmware to get my A1 mini works again but it is impossible…
Do you know any way to install firmware from the SD instead of wifi or some other trick? Many thanks to all :slight_smile:
These printers are close source no one nose how they really work!
Did you fix it finally? Can you print at least? (I not because it gives abnormal temp in nozzle because the bad firmware)
Hi, finally support answer me, we made two tests that they tell me and then send me the TH board and the USB-C cable.
I change them for the new received today and printer appears to work ok, but I had in the first day I print again two times a issue that afraid me: printer stops at the middle of the print (hotend stops on the middle of the piece, but maintaining temperature at 215ºC, then it can be dangerous because it slowly melts and make hot a single point of the piece…)
In that two times the printer is totally stuck, screen doesn´t show nothing, no errors or nothing, and from Bambu Studio or Handy app printer is disappear, no connection…
Do you know something that I can check? I change now the SD card, hope that can be helpful. If it happens again I will contact again with support, but I am very sad because I was 30 days without printer and now I don´t know if this problem will permit me to print again… (I won´t print of night from now because of the stuck problem)
If someone can give me an idea I will be very grateful, thanks!!! :slight_smile:
Probably SD card issue, what you describe is a symptom of a bad or corrupt sd card. I have had to replace a couple cards on a couple printers. They don’t use the highest quality sd cards unfortunately.
I think was that fortunately :slight_smile:
I changed the SD card and today I made several prints without any stuck, hope this continue, many thanks!
I had this problem as well. Used a new San Disk 64gb card and it was solved.
