So I normally print high temp filaments across the board but recently something I designed really only worked best in TPU for it’s intended purposes.., therefore I’ve never had any of the A series or any printer without a heated chamber of some sort.
I did a few production runs of TPU in H2C’s and D’s using external spools with ball bearings etc., and it worked great.
But I didn’t want to tie up those machines with TPU so pulled the trigger on the Mini. Well, just finished the 1st print on it with TPU, talk about perfection!
I honestly have NO IDEA how they can sell this thing for $219 right now. Assembly and unpacking was 5 minutes. Just an absolute INSANE bargain for what you get.
Since this TPU product line I’ll be doing in mass quantities, I’ll be ordering several more of these machines soon.
I just wanted to thank the folks at Bambu for making such an amazing little machine and an absolute INSANE price point for what you get.
Absolutely LOVE my A1Mini. And yes, that thing giggles at TPU. Just an amazingly versatile little guy and it prints it all spot on. Such a cool printer.
I use a lot of TPU and I switched to the variable shore filaments. This makes all the print problems go away.
The stuff is rigid, and when heated it foams, and the bubbles soften it. It works in the printer as it’s rigid as it’s pulled by the extruder, and then you set the nozzle temperature to foam it to whatever softness you want.
I was finally able to print 60A shore tyres with this stuff.
I’m curious how this type of filament would hold up in a manufacturing / industrial environment.
I really like the siraya tech stuff as it has the flexibility but it’s rigid at the same time. Everything else I’ve tried, tries to do this with formulations of PETG or other hard plastics and testing the part shows they are much weaker in comparison.
Every time I try to start a print, the printer gets stuck in a loop. Specifically, the Y-axis moves to the extreme ends of its travel and hits the frame violently, producing a loud, metallic grinding/clacking noise (as shown in the attached videos). It seems like the printer is unable to detect the endstops/homing position properly on the Y-axis.
I have carefully followed all the troubleshooting steps provided: I loosened the rear Y-axis tensioner screw, moved the heatbed back and forth a few times to align the belt, and then retightened the screw to apply the correct tension via the internal spring mechanism. I formatted the MicroSD card. I performed a full Factory Reset on the printer. I ran the complete initial calibration Unfortunately, the issue persists. The Y-axis still experiences travel anomalies, causing the bed to impact the frame and make an abnormal noise at the end of its travel.
I had a Dodge Dart that behaved the same way. Ended up putting over 250k miles on it. Try pumping the two pedals when starting. That usually calmed it down.
Hi all. I getting a bambu A1 mini next week after researching on all the brands and types out there. I was stuck between bambu A1 and A1 mini but decided to go with mini for couple reasons.how much I will use it .space I have and the excellent price and all the reviews.
I’m debating will I get the A1 mini with AMS system or not. Wouldn’t be getting to do much as in colours but , looking at reviews and posts on this forum need 620mm in width to have both which I have . Also learned having a filament dryer is a must . I be mostly using to make parts and bits for my drones and diy parts mostly. A friend showed me his 3d printer so got hooked
Most people don’t realize about electricity usage. Unless you run on solar power, cost adds up fast! That’s why I use A1 mini for most of initial studies and do the production on the larger printers.
I mentioned back in May that I was considering an A1Mini and on the last day of the sale (hey, $10 is $10 after all…) I went ahead and ordered one, and I’m glad I did.
It’s so cute!
It really thrashed around printing the first benchy (not the most solid work table…) but setting it back to “silent 50%” speed settled things right down. I’m keeping it as stock as possible rather than festooning it with addons… just a poop deflector and bucket recycled from the A1 and a handle on top of the gantry. No AMS, feeding just one filament manually.
I love it. It’s been continually busy printing several of my own circuit-board standoffs and mounting brackets and spacers and such and for small parts like this it is perfect. It prints PETG with no drama at all and I’m going to experiment with TPU.
I haven’t had this much fun with a 3D printer since the very beginning. I wonder if I had just started with the bare Mini rather than being seduced by the larger multi-material printers (a capability I rarely use anyway) if I ever would have gone beyond it. It’s just that good.
