A1 Multiple Issues - Hotend cooling fan speed is abnormal, and Z-Axis Homing
Hi, I have a relatively new A1 (<10 hours printing time)
It was working flawlessly whilst I had it indoors, but I recently moved it out to my garage. Since then, almost always without fail, I get a ‘Hotend cooling fan speed is abnormal’ error every time I start a print. I try and manually resume the print and this always sorts itself out after 3 or 4 tries. The fan is definitely working and prints that eventually get started come out just fine.
In the last day or two, I have also occasionally started getting a ‘Z-Axis Homing Failed’. Again, when I restart the print (and sometimes after some more hotend cooling errors), the print will eventually start and print just fine.
The garage is a lot cooler than indoors, so I’m not sure if just some sensor error that’s being affected by the cold?
Any help much appreciated
Thanks
Please, can you share pictures so we can help you out? Because the issues that you get are very generic and can be caused by many different things
Re:Temp, I had to pull my A1 that I keep in the garage back into my home when ambient dropped below 45F, it was causing some noise while moving that made me think the oil/grease was not doing its job in the cold. I didn’t get any error messages though.
For the errors: I would flip it over and re-assess how well the USB-C connector on the bottom is plugged in. Make sure that screw is preventing it from pulling out. Be gentle around the connector.
I’m not sure what I can show you other than the error message on the screen!
Thanks, I’ll take a look. It just doesn’t make sense that it always starts working eventually after 4-5 restart attempts, then continues to print just fine
see i purchased a a1 mini recently each time i start print it shows the hotend fan speed is abnormly slow but when i move the fan with hand it starts and print starts how to solve this issue
