A1 printer not working
Hello,I’m using an A1 printer with an AMS. I’m using both Bambu Handy and Bambu studio. Everything was good until it suddenly wasn’t.
I bought the printer new back in 23 but I’ve had a couple strokes since then so it’s been barely used. My youngest has been using it for last few weeks printing out dnd miniatures till it clogged/produced nothing but strings. I came down to a hammer and some tools. So far I’ve replaced the heating assembly, the hot head and the build plate. Made sure all the screws were tight. Everything calibrates but when I go to print a model nothing or very little filament comes out. My right hand trembles a lot now so I might have bumped something.
Any help would be great.
Hallo
Kontrolliere die Düse wegen Verstopfung ( dünne Nadel )
Filament 1,75 mm im Durchmesser ? nicht das 2,85 mm Kontrolliere es .Kontrolliere die Temperatur der Düse beim Druck .
Von Hand manuell das Filament unterstützen beim Einschub beim Druckversuch wenn Filament läuft liegt es dann högstwerscheinlich am Vorschub vom Druckkopf. Ich drücke dir die Daumen .Grüsse gehen raus
I’ll check that out. I’m using the Bambu labs basic pla and a Sunlu pla. They both were working fine before all of this. Seems all files won’t work.
