A1 printer won't print after being sent to printer
After not having used my printer for a few weeks, I tried to print a model I’ve printed before but after I have sliced and sent to printer and everything is looking fine and normal, the printer will not start.
I"ve gone through the calibration sequence again all to no avail.
The same thing is happening whether I use the AMS lite of the external spool.
Here’s screenshot. Screenshot by Lightshot
Any suggestions most welcome.
On the printer, go to printer settings and re connect it to your wifi, it may have lost connection or you may have changed the password since etc etc.
Looks to me Bambu Studio isn’t detecting the printer on your local connection.
First check that your SD card is inserted correctly.
If there is a SD card inserted you may what to try a different one as the current one might be failing.
