Ability to move a model using -Z setting to move part of the model “below” the print bed. I have several models that need to be moved down 1mm or so in order to make sure the bottom of the model is 100% in contact with the bed.
Can you not just cut/split the model at 1mm height and discard the lower piece?
Hi,
at the risk of saying something stupid but the function exists in Bambu Studio and allows a cut on all axes. You just have to make a horizontal cut at the desired height and uncheck the box allowing to keep the lower part.
This was super helpful. It’s now called Object A and Object B instead of upper and lower (so deselect B).
