Abnormal Extruder Eddy, Nozzle not installed followed by Z homing failed
Hello
I recently had issues with my h2s. After reloading filament to continue my print. I noticed that I couldn’t get my filament to load properly. I took the nozzle off and saw that there was left over filament stick out under the extruder that was stuck. I had to use needle nose pliers to pull it out
When I reseated the nozzle I started receiving multiple errors.
  • “Abnormal extruder eddy current signal, the sensor may be damaged or the MC-TH communication may”,
  • Then followed by “Nozzle may not be installed or not properly seated”,
  • And now stuck at “z Homing failed” The task has been stopped"
I can manually extrude the filament but can’t get past the last errror when i attempt to start a new prins. I have tested 3 separate nozzles and still get the errors. i do not know if the sensor is damage. I looked at the sensor and can visibly see copper wire between its plastic housing and the tape covering it. But from what i understand that doesn’t matter since it doesnt interfere with the induction. I followed Bambu techs recommendation to look and reseat the connector to the board. I didn’t see any thing wrong with the plug
I tried readjusting the eddy sensor the best i could but its been very hard since you cant tighter the screw to fix it into the right level with the screws behind the nozzle assembly. I wonder if there is a better way to do this.
Im at a loss and have been stessed out trying to figure a way to fix this or determine what is the main problem. Any others have this exact problem thanks
