What does it mean? The retraction is completely disabled or the retraction is active with the default settings, ie those ? (example bamboo PLA)
In English, that tab is named “Setting overrides”.
'nuff said.
Thank you, my English is poor but I understood this point! But that doesn’t quite answer my question!
Because just checking the boxes shown a by default value. So for me, when i check a box, it means i select the value , not i change it !
I don’t understand.
There are default settings set for the printer, like retraction length and speed.
You can use different settings for specific filaments that need a different setting.
To do that, you go to this tab, select what you want to override and put in a new value.
ok i will try to be more clear :
When you open the setting for a filament provided by BambuLab the first time, and go in the tab “Setting overides”, on the screen you have all chexboxes unchecked. Generally, when a chexkbox is unchecked, it’s means that the option is disabled. So, when you open the tab “Setting overides”, all the checkboxes are uncheked : so for me it means that all the options fort retractation are disabled, so globally the retractation is disabled !
Do you understand ?
ok, it’s clear now
Thank to all
