We print a file, and it prints perfect, and then you print 20 other files, and go back to the original, but want it printed in multi material, but can’t remember what settings were used for said print.
It would be nice if we could download the 3MF, or whatever file is sent over the cloud, so we can import the project with the correct settings?
However, there’s one file in particular that I’m having issues with, and its gotten alot of attention when I didn’t think it would, now I’m having issues printing it to the same standard that I did before. lol
I print 2 kg of a tpu part every 3 months. It is a very difficult part to print and took months to dial my settings. I somehow lost all settings in my project file when I tried to add another printer in Orca. I can’t seem to replicate the settings in the file I have been printing. Luckily for now I can reprint it from my history in the app but have no other way to print it.
Where is the history saved, in the bambu cloud or in the printer? Is the app the only place to see your history? I would really feel better if I could download or permanently save that 3mf or gcode file.
That history file is all I have and I am terrified I am going to lose it because of the long period of time between prints of this file.
It looks like they are saved to the micro sd card, you might be able to plug the card into your computer and pull them off of it. I’ll update yall if it works
Software updates to Bambu Studio can also be a factor. The update before last changed some support parameters somehow and I had tweaked the support angle to keep it out of places I didn’t want it. After the update it was putting support where I didn’t want it again and again I had to tweak the setting to get it fixed.
I think when all is said and done, if you want to print lots of something and not have to deal with settings or slicer changes is to save the G-code. And even with that, printer firmware updates could still change things up.
Where are you seeing all the prints being saved to the microSD card? Is it in a hidden folder or somewhere not obvious? If I send a print to the printer, then it’s saved to the microSD Card but if I just “Print” or print from the app then it appears nothing is saved locally. I
On the P/A series of printers all prints are saved to the SD card. On the X series you have to turn on the “Save copy of print to SD card” feature (as well as add a SD card).
Thank you for posting, I ran out of ideas searching on my computer and the A1 memory card… It shows last 18 jobs and I needed an older file reprinted… not on the list, so I tried everywhere I could go and find the “original” file, which I had to reduce to fit… That’s what I’m looking for: the final size it was printed.
I followed your directions and FOUND THE SOLUTION!!!
THANKS.
