Account login and network issues on my p1s
  • Printer model used
  • Slicer settings used
  • Type of filament used
first idk if this is the right section .
I got a new router, so my P1S lost its WiFi connection. I reset the network settings on the printer to reconnect it, but this logged my printer out of my Bambu account.
Now I can’t re-bind the printer to my account. The printer shows a QR code, I scan it with the Bambu Handy app, and the app opens and asks me to pair via Bluetooth. I grant all permissions and press “Pair” on both my smartphone and the printer display. It then searches for a network for a few seconds and suddenly jumps back to the beginning – showing “Bluetooth connection failed.”
I’ve tried this on 2 different smartphones with the same result. I also tried via Bambu Studio on PC, but you can’t generate a binding/connect code without the printer being linked to your account first – so that’s also a dead end.
The printer has no LAN port. I’ve already done a full factory reset on the printer multiple times. Nothing helps. Bluetooth pairing never succeeds, it always fails at the network search step.
Maybe this process will help:
https://www.reddit.com/r/BambuLab/comments/1927uqm/setup_tip_for_p1sanyone_who_cant_bindpair_account/
thx mate it kindof worked , the part with the .cfg was good , rest was fiddeling af but igot it almost working now p1s paired with app , but lan only doesnt work correctly bambustudio cant find the printer although same network -.- 2 years without problems and now this… i dont need cloud uploads slow af and i never use the crappy app aswell
