Hello dear community!
Bambu Studio generates some acrobatic runs that damage the part I want to print. PrusaSlicer does it correctly, can you help me solve the problem? Thank you very much!
Do you have timelapse enabled?
When the head moves away from the part at each layer to take the timelapse picture it helixs off of the part to reduce stringing. These are the “acrobatic” moves you are seeing.
It looks like you are referring to the Spiral Z hop in Bambu Studio, which is used to minimise the stringing effect.
Considering the print quality, it is recommended to double check that the Z seam is aligned. In your situation, it would be recommended to paint it on the internal section of the model, which can hide it better and provide a better result.
Hi @JonRaymond, thank you very much for the quick response!
I just modified the parameter you mentioned and it does indeed seem to improve, although it still makes the turns in the seam area. I still need to print the piece to see the physical result. I will let you know the final result!!
Hello @SupportAssistant, thank you very much for the very precise answer!
I have modified the timelapse parameter and it has improved. Modifying the stitching to ALIGNED, it does not seem to improve (I have to do more tests painting by hand). Regarding the Z jump in TURN mode, I have selected NORMAL and it seems to continue doing the same thing. I have just discovered this RETRACTION section, I am going to do some tests and I will let you know. I am very grateful for the support!!
Did you manage to solve the problem? It’s 2026, and I’m running into the same issue with ERYONE ASA. I’ve found about five threads on various forums—including this one—but there’s no solution anywhere.
Hi, I finally solved it. I think it was fixed by installing the filament manufacturer’s profile in the laminator. Cheers!
I’m really happy for you, dude! But the problem is clearly software-related. I’ve seen several other forum threads where they printed the same part with the same material in a different slicer for testing purposes, and everything was perfect. And there’s no standard profile for my Eryone ASA.
