Activate Air Filtration
Does anyone know if ticking the “Activate Air Filtration” box under “Exhaust Fan” in printer settings has any result on H2D (without the optional air filtration upgrade), and if so - what?
I have used it to get some cooling after print has finished and that seems to work. But I wouldn’t want it to affect the exhaust fan during a print with heated chamber.
It will activate the chamber fan. However, if both this setting and the filament profile enable it—especially with high-temperature materials—the printer can enter a limbo state: it starts the chamber fan while still treating the system as in heating mode, so the fan runs while the top inlet remains closed. I also use it to evacuate the chamber after a print to speed cooling and reduce VOCs.
It allows you to control the speed of the exhaust fan in the filament profiles.
