Add a svg to a model
hi. how to add a svg logo to a model and print it in the first layer as flat?
thanks
Check out the instructions I’ve made for my model:
That should give you good idea on how to do it :slight_smile:
I open a svg logo, then i open as geometry the object. I move the svg under the object, I merge them
but the object always start from 2nd or 3d layer !
Select the object and use the move command to move it down in Z.
I used the move command and moved the object on the plate. But object and svg are always on different layers.
Here an example. The first layer begins with the box and the 2nd with svg.
Why??
As soon as you have merged the objects, ensure that you select only on of the merged objects. According your screenshots you have to select the box only (not the merged group!) and move the box down a bit, that it is on the same level as your logo.
I am having this issue too, I was able to get it to work once but now I can’t get it to work again and I can’t remember how I did it.
