Similar to how this klipper plugin works, but instead of a long line in the same place, how about making the purge line much thicker, and place it near the model. So you can take it off easier when you take off model.
I’m not sure what is the benefit of these adaptive purge lines, beyond just location change and shape change…
How would it benefit anyone?
Because they are thicker and in the more in middle of build plate, they will pop off easier.
It usually takes me more time to remove the current long thin purge line than my entire model.
yes this is close, but since you can’t even turn off purge/prime line, then this is moot. And you would just have 2 primes now.
Sure you can, just edit them out of the start gcode.
Thanks for the correction, when I checked before posting I had Process set to “Objects” and it doesn’t show it.
Print those small bambu plastic scrapers and the purge line comes off very easily.
They state the benefits as follows:
- No wasted probe information
- KAMP will generate a mesh only in the area you actually need it: Where you’re printing!
- Since the mesh area will be smaller, the mesh can be much more dense. Imagine making a 3x3 mesh, but the size of a 3DBenchy!
It becomes even more beneficial the larger the build plate. , because you aren’t wasting time probing the bed far away from where you’ll be printing. Like it says: it can either avoid wasted time or else give a more precise bed leveling in the same amount of time if you have an especially topsy-turvey build plate but need the precision anyway.
Just want to do a shoutout and let you know that I support this cause. It’s something I’ve been wanting on my X1C for a long time!
Both adaptive mesh leveling and an adaptive purge line. These two options are perfectly possible on the X1C and it would make the machine so much more user friendly.
FWIW, Teaching Tech has an episode on how to do adaptive purge lines in Marlin and in Klipper. Not sure, but maybe (?) one can extrapolate from that how to do the same on a Bambu.
Teaching Tech’s latest video is about it. It has quite a few interesting advantages
There was a way to use adaptive mesh on a P1S until Bambu updated the firmware to 01.07 a week ago. Hope Bambu will support adaptive mesh the future natively. This is a so useful and timesaving feature!
Yeah it worked before that update, I hope they make it work with newer updates again, maybe even add a checkbox next to the bed level one for adaptive on or off
