If Filament manager was linked to my account… AND it IS
When I order filament and you tracked that it is delivered… AND you DO
Then: The filament should be added to my filament manager… without unboxing each one, loading it into an AMS. Having to do this step makes filament manager useless, and is not even close to what filament I have.
As an alternative you could allow the scanning of the filament with the handy app, as an inventory check-in when the filament arrives.
+1 for this. Until something like it exists, a workaround that works well: do the check-in when the box arrives, not when the spool goes into the AMS. Note brand, material, color and the date, and weigh the spool once with the empty-spool weight subtracted.
Then, when it finally goes into the AMS, you only match it to an entry that already exists instead of creating it, and the list stays close to what is actually on the shelf. It takes about a minute per delivery.
