Add G codes within layers
I was wondering how to insert G code within a layer i.e. at a certain line number. I can see insert at the beginning of a layer like pause, but I wish to add g codes at specific line numbers. Basically I can load a 3mf file or stl into Bambu and slice it according to my filament speed strength, etc setting then export the result into a gcode file that includes all the lines of code including what the slicer has updated. Now I wish to view the gcode line by line and see what effect the gcode line has to the model, sort of like ths slicer shows the model and the gcode, but now you are working in an editor so you can make changes and save the changed gcode file, back to the printer then…
Editing the Gcode output from Bambu Studio is doable about I would really caution you against it as it’s really easy to get in over your head and there is potential for crashing/damaging your machine.
