Add model to group
I don’t know if I’m blind or if this feature just doesn’t exist, if it does please tell me how to use it.
So when you add an stl with multiple models, you get the option to split this model in to objects or parts. But there is no way to add multiple objects to one group. Which is very handy when using a mix of print order, like you want to print 5 objects in one color and a sixth with its own color. If you set them all up to print by object they wont fit the build plate, but if you print the first 5 together and only the sixth with its own color alone they would fit and print a lot faster.
I use ‘assemble’ to group objects of the same colour when doing ‘by object’ prints.
You need to move them close together on the plate before assembling
Yea that’s exactly what I was looking for, thanks!
Found it as MERGE today, maybe it has been renamed. Or german version or some reason, just for the next guy not finding assenble :wink:
I’d like to further clarify this.
There’s an “Assemble” button in the toolbar which is NOT what you want to use.
You need to go to the Objects tree in the side panel, select the bodies that you want to group, right click and choose “Merge”.
