Hello,
TL;DR;
Bring back a way to have the printer connected to cloud mode, and still control it from local.
Long version:
i have the printer connected to the cloud, because my wife also uses it, and it is connected to her cloud account. The main reason to use cloud, is the handy app for monitoring her print and notification when it is done
I myself use linux, can’t use bambu slicer and use orcaslicer, and use lan mode for this. This for multiple reasons, tolong.
First we switched the printer between her and my cloud account, but that resets the local access token every time, which is annoying because i have the printer monitored by home assistant and i don’t want to use the cloud for that. mostly because i don’t want to lose the monitoring if bambu/theinternet/myisp goes down
So the only option i have with the new firmware
- use the cloud account of my wife, but that would also change here profiles, i don’t want that
- reset the local access token every time, this is a hassle
- switch my wife also to lan mode, this seems to be the only alternative
So please add one or more of the following features:
- add a file on the SD, which pins the local access code, even when logging in/out of the cloud account
- add a
yes-i-know-this-is-dangerous.txtfile on the sdcard re-enables the local access like previous firmware
for now my option is, stay with the old firmware, but i know for sure this will break in the future when some new feature requires a new firmware
