I’m moving my designs from old model sharing platforms to makerworld, and of course working to setup appropriate print profiles for them too.
One of my designs is a self-watering flower pot. It consists of a vase-mode outer shell which holds the water, and a non-vase-mode insert which holds the dirt/plant. I designed it to use vase mode as that generally resulted in a more reliable water-tight result.
I can upload two print profile 3MFs to makerworld, but that feels wrong: it is implied that each profile would include the entire design and i’d have to somehow communicate that this isn’t the case for my profiles. i don’t want to seed a trend for people to eventually upload one profile for each build plate…
Bambu Studio allows me to set the global feature [spiral vase]. I cannot toggle this setting per-object though, and there is no option to control settings per-plate. Therefore I cannot create a single print profile 3MF that will work for all the parts of my design.
Is this so niche that it wouldn’t help others? I don’t know. It’s an issue I’m facing and it feels reasonable to add as a new feature request so here I am.
I would also like to have this feature. I found this post while searching for a solution, since I find myself in a similar situation: my project has some plates to be printed in vase mode, and others by layer. Interestingly, I can customize the print order for each plate, but not the vase mode.
I would like this feature as well with the option to set vase mode per object instead of by plate if the print sequence is set to by object for the plate.
i would like to print a design with a heavy standard base, and then the upper portion in vase mode for aesthetics and speed. So I second the request to have this avail as a per object option
If you mean two objects on the same plate, one with vase mode and the other without it, then you have an issue as the idea of vase mode is a continual path of filament moving up as it goes around the model’s perimeter.
Mixing a non-vase-mode and vase-mode model on the same plate would prohibit the vase-mode action from occurring if it had to start and stop then over to the second model per layer as vase mode doesn’t use the concept of layers.
Having vase mode per plat means you can have the base on one and the upper portion on another.
Bump, looking for a solution to have one profile, Plate 1 vase mode, plate 2 not vase mode. Seems like all they’d have to do is leave it as an option under OBJECT instead of Global…
I also would like the option to switch from Spiral mode on the SAME plate - obviously not on the same layer, but for one object with an angled cut at the top. Spiral mode obviously fails for the upper angled portion, which I understand. But if I can make it switch at a given Z/layer, it would work fine. e.g… Spiral mode for layers 1-500, normal mode for layers 501-600.
Until this is implemented, can anyone suggest a workaround other than printing separately and gluing, which would look terrible?
Currently I am expanding the model to not have an angled edge, wasting print time and material, and then manually sawing off the angle. Not great.
